Some programming languages for LOGSPACE and PTIME - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We propose two characterizations of complexity classes by means of programming languages. The first concerns Logspace while the second leads to Ptime. This latter characterization shows that adding a choice command to a Ptime language (the language WHILE of Jones) may not necessarily provide NPtime computations. The result is close to Cook who used “auxiliary push-down automata”. Logspace is obtained through a decidable mechanism of tiering. It is based on an analysis of deforestation due to Wadler in. We get also a characterization of NLogspace.
bonfante.pdf (199.55 Ko) Télécharger le fichier
inria-00105744 , version 1 (12-10-2006)
  • HAL Id : inria-00105744 , version 1
Guillaume Bonfante. Some programming languages for LOGSPACE and PTIME. 11th International Conference on Algebraic Methodology and Software Technology - AMAST'06, Jul 2006, Kuresaare/Estonie. ⟨inria-00105744⟩
116 Consultations
318 Téléchargements
