3D Sketching with profile curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In recent years, 3D sketching has gained popularity as an efficient alternative to conventional 3D geometric modeling for rapid prototyping, as it allows the user to intuitively generate a large range of different shapes. In this paper, we present some sketching interactions for 3D modeling, based on a set of two different bidimensional sketches (profile curve and silhouette curve). By using these two sketches and combining them with a gesture grammar, a very large variety of shapes (including shapes with topological holes) can be easily produced by our interactive modeling environment.
Article.pdf (1.49 Mo) Télécharger le fichier
Format : Figure, Image
inria-00106823 , version 1 (16-10-2006)
inria-00106823 , version 2 (27-10-2013)
Floriant Levet, Xavier Granier, Christophe Schlick. 3D Sketching with profile curves. International Symposium on Smart Graphic, Sep 2006, Vancouver, Canada. pp.114-125, ⟨10.1007/11795018_11⟩. ⟨inria-00106823v2⟩
Relations
201 Consultations
607 Téléchargements
