Transactional Patterns for Reliable Web Services Compositions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Sami Bhiri
  • Fonction : Auteur
  • PersonId : 755745
  • IdRef : 093328702
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 830785
Reliability is one of the main challenge that encounter Web services compositions. Due to the inherent autonomy and heterogeneity of Web services it is difficult to predict the behavior of the overall composite service. Current related technologies are unable to resolve this problem efficiently. These technologies rely on two existing strong approaches: transactional processing and workflow systems. In one hand transactional processing ensures reliability. However, they are too rigid to support process based applications like composite Web services. On the other hand, workflow systems focus mainly on coordination and organizational aspects and ignore reliability issues. In this paper we propose a new solution that combines the business process adequacy of workflow systems and the reliability of transactional processing. We introduce the concept of transactional patterns to ensure reliable composite services. A transactional pattern can be seen as a convergence concept between workflow patterns and advanced transactional models. We show how we use it to define composite services and how we ensure their reliability according to the designers specific needs.
ICWE-published-Bhiri.pdf (756.54 Ko) Télécharger le fichier
inria-00113956 , version 1 (15-11-2006)
Sami Bhiri, Claude Godart, Olivier Perrin. Transactional Patterns for Reliable Web Services Compositions. 6th International Conference on Web Engineering - ICWE 2006, Jul 2006, Palo Alto, California, United States. pp.137-144, ⟨10.1145/1145581.1145613⟩. ⟨inria-00113956⟩
158 Consultations
230 Téléchargements
