s'authentifier
version française rss feed
inria-00115386, version 1
Geometrically Exact Dynamic Splines
Adrien Theetten () a1, Laurent Grisoni 2, Claude Andriot 3, Brian Barsky 4
(2006)
Résumé : In this paper, we propose a complete model handling physical simulation of deformable 1D objects. We formulate continuous expressions for stretching, bending and twisting energies. These expressions are mechanically rigorous and geometrically exact. Both elastic and plastic deformations are handled to simulate a wide range of materials. We validate the proposed model on several classical test configurations. The use of geometrical exact energies with dynamic splines provides very accurate results as well as interactive simulation time, which shows the suitability of the proposed model for constrained CAD applications. We illustrate the application potential of the proposed model by describing a virtual system for cable positioning, that can be used to test compatibility between planned fixing clip positions, and mechanical cable properties.
  • Domaine : Informatique/Synthèse d'image et réalité virtuelle
  • inria-00115386, version 1
  • oai:hal.inria.fr:inria-00115386
  • Contributeur :
  • Soumis le : Mardi 21 Novembre 2006, 11:35:03
  • Dernière modification le : Mardi 21 Novembre 2006, 11:45:28
tous les articles de la base du CCSd...
