Functional Brain Imaging with Multi-Objective Multi-Modal Evolutionary Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Functional brain imaging is a source of spatio-temporal data mining problems. A new framework hybridizing multi-objective and multi-modal optimization is proposed to formalize these data mining problems, and addressed through Evolutionary Computation (EC). The merits of EC for spatio-temporal data mining are demonstrated as the approach facilitates the modelling of the experts' requirements, and flexibly accommodates their changing goals.
draft_PPSN06.pdf (928.6 Ko) Télécharger le fichier
inria-00116342 , version 1 (26-11-2006)
Vojtech Krmicek, Michèle Sebag. Functional Brain Imaging with Multi-Objective Multi-Modal Evolutionary Optimization. PPSN'06, Sep 2006, Reykjavik, pp.382-391. ⟨inria-00116342⟩
96 Consultations
216 Téléchargements
