s'authentifier
version française rss feed
inria-00116344, version 1
Genetic Programming for Kernel-based Learning with Co-evolving Subsets Selection
Christian Gagné a12, Marc Schoenauer () b13, Michèle Sebag () c3, Marco Tomassini a2
PPSN'06 4193 (2006) 1008-1017
Résumé : Support Vector Machines (SVMs) are well-established Machine Learning (ML) algorithms. They rely on the fact that i) linear learning can be formalized as a well-posed optimization problem; ii) non-linear learning can be brought into linear learning thanks to the kernel trick and the mapping of the initial search space onto a high dimensional feature space. The kernel is designed by the ML expert and it governs the efficiency of the SVM approach. In this paper, a new approach for the automatic design of kernels by Genetic Programming, called the Evolutionary Kernel Machine (EKM), is presented. EKM combines a well-founded fitness function inspired from the margin criterion, and a co-evolution framework ensuring the computational scalability of the approach. Empirical validation on standard ML benchmark demonstrates that EKM is competitive using state-of-the-art SVMs with tuned hyper-parameters.
  • Domaine : Informatique/Intelligence artificielle
  • inria-00116344, version 1
  • oai:hal.inria.fr:inria-00116344
  • Contributeur :
  • Soumis le : Dimanche 26 Novembre 2006, 11:45:19
  • Dernière modification le : Lundi 27 Novembre 2006, 15:38:55
tous les articles de la base du CCSd...
