Scheduling for Responsive Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Grid Computing Année : 2008
In the 70s, the transition from batch systems to interactive computing fueled the widespread diffusion of advances in integrated circuit technology. Grids are facing a similar challenge, namely the seamless integration of the grid power into everyday use. One critical component for this integration is responsiveness, the capacity to support on-demand computing and interactivity. A large contributor to responsiveness is the Quality of Service (QoS) for the job execution time. Grid scheduling is involved at two levels in order to provide QoS: the policy level and the implementation level. The main contributions of this paper are as follows. First, we present a detailed analysis of the performance of the EGEE grid with respect to responsiveness. Second, we define and demonstrate a virtualization scheme, which achieves QoS, schedulability analysis, and coexistence of QoS and best-effort poli- cies, within a brokering-based system organized as a federation of batch-scheduled clusters. Last, we examine two user-level schedulers located between the general scheduling layer and the application layer. These are the DIANE (DIstributed ANal- ysis Environment) framework, a general-purpose overlay system, and a specialized, embedded scheduler for gPTM3D, an interactive medical image analysis application.
GRID-S-06-36.pdf (1.05 Mo) Télécharger le fichier
inria-00117486 , version 1 (01-12-2006)
Cecile Germain-Renaud, Charles Loomis, Jakub Moscicki, Romain Texier. Scheduling for Responsive Grids. Journal of Grid Computing, 2008, 6 (1), pp.15-27. ⟨10.1007/s10723-007-9086-4⟩. ⟨inria-00117486⟩
451 Consultations
251 Téléchargements
