s'authentifier
version française rss feed
inria-00128861, version 1
Observational Semantics for a Concurrent Lambda Calculus with Reference Cells and Futures
Joachim Niehren () 1, David Sabel 2, Manfred Schmidt-Schauß 2, Jan Schwinghammer 3
23rd Conference on Mathematical Foundations of Programming Semantics 173 (2007) 313-337
Résumé : We present an observational semantics for lambda(fut), a concurrent lambda calculus with reference cells and futures. The calculus lambda(fut) models the operational semantics of the concurrent higher-order programming language Alice ML. Our result is a powerful notion of equivalence that is the coarsest nontrivial congruence distinguishing observably different processes. It justifies a maximal set of correct program transformations, and it includes all of lambda(fut)'s deterministic reduction rules, in particular, call-by-value beta reduction.
  • Domaine : Informatique/Langage de programmation
  • inria-00128861, version 1
  • oai:hal.inria.fr:inria-00128861
  • Contributeur :
  • Soumis le : Mercredi 7 Mars 2007, 16:16:47
  • Dernière modification le : Lundi 14 Décembre 2009, 22:24:30
tous les articles de la base du CCSd...
