Analysis of Steiner subtrees of Random Trees for Traceroute Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2008
Fabrice Guillemin
We consider in this paper the problem of discovering, via a traceroute algorithm, the topology of a network, whose graph is spanned by an infinite branching process. A subset of nodes is selected according to some criterion. As a measure of efficiency of the algorithm, the Steiner distance of the selected nodes, i.e. the size of the spanning sub-tree of these nodes, is investigated. For the selection of nodes, two criteria are considered: A node is randomly selected with a probability, which is either independent of the depth of the node (uniform model) or else in the depth biased model, is exponentially decaying with respect to its depth. The limiting behavior the size of the discovered subtree is investigated for both models.
main.pdf (249.09 Ko) Télécharger le fichier
tree.pdf (31.89 Ko) Télécharger le fichier
inria-00133676 , version 1 (27-02-2007)
inria-00133676 , version 2 (06-06-2008)
Fabrice Guillemin, Philippe Robert. Analysis of Steiner subtrees of Random Trees for Traceroute Algorithms. 2008. ⟨inria-00133676v2⟩
Collections
INRIA INRIA2
95 Consultations
254 Téléchargements
