Tom: Piggybacking rewriting on java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present the Tom language that extends Java with the purpose ofproviding high level constructs inspired by the rewriting community. Tom furnishes a bridge between a general purpose language and higher level specifications that use rewriting. This approach was motivated by the promotion of rewriting techniques and their integration in large scale applications. Powerful matching capabilities along with a rich strategy language are among Tom's strong points, making it easy to use and competitive with other rule based languages.
system.pdf (166.18 Ko) Télécharger le fichier
inria-00142045 , version 1 (17-04-2007)
  • HAL Id : inria-00142045 , version 1
Emilie Balland, Paul Brauner, Radu Kopetz, Pierre-Etienne Moreau, Antoine Reilles. Tom: Piggybacking rewriting on java. Conference on Rewriting Techniques and Applications - RTA'07, Jun 2007, Paris/France, France. pp.36-47. ⟨inria-00142045⟩
271 Consultations
790 Téléchargements
