Computing deep facet-defining disjunctive cuts for mixed-integer programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of separation is to find an affine hyperplane, or ''cut'', that lies between the origin O and a given closed convex set Q in a Euclidean space. We focus on cuts which are deep for the Euclidean distance, and facet-defining. The existence of a unique deepest cut is shown and cases when it is decomposable as a combination of facet-defining cuts are characterized using the reverse polar set. When Q is a split polyhedron, a new description of the reverse polar is given. A theoretical successive projections algorithm is proposed that could be used to compute deep facet-defining split cuts.
RR-6177.pdf (242.48 Ko) Télécharger le fichier
inria-00144289 , version 1 (02-05-2007)
inria-00144289 , version 2 (02-05-2007)
  • HAL Id : inria-00144289 , version 2
Florent Cadoux. Computing deep facet-defining disjunctive cuts for mixed-integer programming. [Research Report] RR-6177, INRIA. 2007, pp.22. ⟨inria-00144289v2⟩
124 Consultations
367 Téléchargements
