Insight Into Efficient Image Registration Techniques and the Demons Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
As image registration becomes more and more central to many biomedical imaging applications, the efficiency of the algorithms becomes a key issue. Image registration is classically performed by optimizing a similarity criterion over a given spatial transformation space. Even if this problem is considered as almost solved for linear registration, we show in this paper that some tools that have recently been developed in the field of vision-based robot control can outperform classical solutions. The adequacy of these tools for linear image registration leads us to revisit non-linear registration and allows us to provide interesting theoretical roots to the different variants of Thirion's demons algorithm. This analysis predicts a theoretical advantage to the symmetric forces variant of the demons algorithm. We show that, on controlled experiments, this advantage is confirmed, and yields a faster convergence.
InsightEffRegDemons-IPMI07-Vercauteren.pdf (453.94 Ko) Télécharger le fichier
inria-00165534 , version 1 (26-07-2007)
Paternité
Tom Vercauteren, Xavier Pennec, Ezio Malis, Aymeric Perchant, Nicholas Ayache. Insight Into Efficient Image Registration Techniques and the Demons Algorithm: Insight Into Efficient Image Registration Techniques and the Demons Algorithm. Information Processing in Medical Imaging, Jul 2007, Kerkrade, Netherlands. pp.495-506, ⟨10.1007/978-3-540-73273-0_41⟩. ⟨inria-00165534⟩
283 Consultations
1017 Téléchargements
