s'authentifier
version française rss feed
inria-00167176, version 1
Computing the Union of 3-Colored Triangles
Jean-Daniel Boissonnat () 1, Olivier Devillers () a1, Franco Preparata b2
International Journal of Computational Geometry & Applications 1, 2 (1991) 187-196
Résumé : Given is a set \s\ of $n$ points, each colored with one of $k \geq 3$ colours. We say that a triangle defined by three points of \s\ is 3-colored if its vertices have distinct colours. We prove in this paper that the problem of constructing the boundary of the union \ts\ of all such 3-colored triangles can be done in optimal $O(n \log n)$ time.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00167176, version 1
  • oai:hal.inria.fr:inria-00167176
  • Contributeur :
  • Soumis le : Jeudi 16 Août 2007, 11:55:14
  • Dernière modification le : Jeudi 16 Août 2007, 11:59:42
tous les articles de la base du CCSd...
