Shock Structure in a Two-phase Isothermal Euler Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We have performed a traveling wave analysis of a two phase isothermal Euler model to exhibit the inner structure of shock waves in two-phase flows. In the model studied in this work, the dissipative regularizing term is not of viscous type but instead comes from relaxation phenomena toward equilibrium between the phases. This gives an unusual structure to the diffusion tensor where dissipative terms appear only in the mass conservation equations. We show that this implies that the mass fractions are not constant inside the shock although the Rankine-Hugoniot relations give a zero jump of the mass fraction through the discontinuities. We also show that there exists a critical speed for the traveling waves above which no C 1 solutions exist. Nevertheless for this case, it is possible to construct traveling solutions involving single phase shocks.
RR-6274.pdf (358.96 Ko) Télécharger le fichier
inria-00168787 , version 1 (30-08-2007)
inria-00168787 , version 2 (31-08-2007)
  • HAL Id : inria-00168787 , version 2
Hervé Guillard, Vincent Perrier. Shock Structure in a Two-phase Isothermal Euler Model. [Research Report] RR-6274, INRIA. 2007, pp.23. ⟨inria-00168787v2⟩
594 Consultations
173 Téléchargements
