s'authentifier
version française rss feed
inria-00169080, version 5
Analysis of a quadratic programming decomposition algorithm
William Hager a1, Guy Bencteux () b2, Eric Cancès c2, Claude Le Bris () c2
N° RR-6288 (2007)
Résumé : We analyze a decomposition algorithm for minimizing a quadratic objective function, separable in x1 and x2, subject to the constraint that x1 and x2 are orthogonal vectors on the unit sphere. Our algorithm consists of a local step where we minimize the objective function in either variable separately, while enforcing the constraints, followed by a global step where we minimize over a subspace generated by solutions to the local subproblems. We establish a local convergence result when the global minimizers nondegenerate. Our analysis employs necessary and sufficient conditions and continuity properties for a global optimum of a quadratic objective function subject to a sphere constraint and a linear constraint. The analysis is connected with a new domain decomposition algorithm for electronic structure calculations.
  • inria-00169080, version 5
  • oai:hal.inria.fr:inria-00169080
  • Contributeur :
  • Soumis le : Mardi 2 Juin 2009, 16:44:56
  • Dernière modification le : Mardi 2 Juin 2009, 21:23:38
tous les articles de la base du CCSd...
