Realistic Face Animation From Sparse Stereo Meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Being able to produce realistic facial animation is crucial for many speech applications in language learning technologies. For reaching realism, it is necessary to acquire and to animate dense 3D models of the face. Recovering dense models is often achieved using stereovision techniques. Unfortunately, reconstruction artifacts are common and are mainly due to the difficulty to match points on untextured areas of the face between images. In this paper, we propose a robust and fully automatic method to produce realistic dense animation. Our input data are a dense 3D mesh of the talker obtained for one viseme as well as a corpus of stereo sequences of a talker painted with markers that allows the face kinematics to be learned. The main contribution of the paper is to transfer the kinematics learned on a sparse mesh onto the 3D dense mesh, thus allowing dense facial animation. Examples of face animations are provided which prove the reliability of the proposed method.
Mots clés
bergerAVSP.pdf (404.57 Ko) Télécharger le fichier
inria-00169216 , version 1 (02-09-2007)
  • HAL Id : inria-00169216 , version 1
Marie-Odile Berger. Realistic Face Animation From Sparse Stereo Meshes. International Conference on Auditory-Visual Speech Processing 2007 - AVSP 2007, Antonie Bors, Emiel Krahmer, Marc Swerts, Jean Vroomen, Sep 2007, Hilvarenbeek, Netherlands. pp.62--67. ⟨inria-00169216⟩
95 Consultations
95 Téléchargements
