s'authentifier
version française rss feed
inria-00177693, version 2
Designing a commutative replicated data type
Marc Shapiro () a1, Nuno Preguiça () b2
N° RR-6320 (2007)
Résumé : Commuting operations greatly simplify consistency in distributed systems. This paper focuses on designing for commutativity, a topic neglected previously. We show that the replicas of any data type for which concurrent operations commute converges to a correct value, under some simple and standard assumptions. We also show that such a data type supports transactions with very low cost. We identify a number of approaches and techniques to ensure commutativity. We re-use some existing ideas (non-destructive updates coupled with invariant identification), but propose a much more efficient implementation. Furthermore, we propose a new technique, background consensus. We illustrate these ideas with a shared edit buffer data type.
  • Domaine : Informatique/Informatique et langage
    Informatique/Calcul parallèle, distribué et partagé
    Informatique/Algorithme et structure de données
  • Mots-clés : Data replication – optimistic replication – commutative operations
  • Référence interne : RR-6320
  • Versions disponibles :  v1 (09-10-2007) v2 (10-10-2007)
  • inria-00177693, version 2
  • oai:hal.inria.fr:inria-00177693
  • Contributeur :
  • Soumis le : Mercredi 10 Octobre 2007, 09:02:08
  • Dernière modification le : Mercredi 10 Octobre 2007, 09:02:31
tous les articles de la base du CCSd...
