Self-Constrained Resource Allocation Procedures for Parallel Task Graph Scheduling on Shared Computing Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Tchimou N'Takpé
  • Fonction : Auteur
  • PersonId : 830679
Frédéric Suter
Two of the main characteristics of computation grids are their heterogeneity and the sharing of resources between different users. This is the cost of the tremendous computing power offered by such platforms. Scheduling several applications concurrently in such an environment is thus challenging. In this paper we propose a first step towards the scheduling of multiple parallel task graphs~(PTG), a class of applications that can benefit of large and powerful platforms, by focusing on the allocation process. We consider the application of a resource constraint on the schedule and determine the number of processors allocated to the different tasks of a PTG while respecting that constraint. We present two different allocation procedures and validate them in simulation over a wide range of scenarios with regard to their respect of the resource constraint and their impact on the completion time of the scheduled applications. We find that our procedures provide a guarantee on the resource usage for a low cost in terms of execution time.
ns-scrap.pdf (98.39 Ko) Télécharger le fichier
inria-00179735 , version 1 (16-10-2007)
  • HAL Id : inria-00179735 , version 1
Tchimou N'Takpé, Frédéric Suter. Self-Constrained Resource Allocation Procedures for Parallel Task Graph Scheduling on Shared Computing Grids. 19th IASTED International Conference on Parallel and Distributed Computing and Systems - PDCS 2007, Nov 2007, Cambridge, Massachusetts, United States. ⟨inria-00179735⟩
146 Consultations
84 Téléchargements
