The 3D Primitive Equations in the absence of viscosity: boundary conditions and well-posedness in the linearized case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de Mathématiques Pures et Appliquées Année : 2008
In this article we consider the 3D Primitive Equations (PEs) of the ocean, without viscosity and linearized around a stratified flow. As recalled in the Introduction, the PEs without viscosity ought to be supplemented with boundary conditions of a totally new type which must be \textit{nonlocal}. In this article a set of boundary conditions is proposed for which we show that the linearized PEs are well-posed. The proposed boundary conditions are based on a suitable spectral decomposition of the unknown functions. Noteworthy is the rich structure of the Primitive Equations without viscosity. Our study is based on a modal decomposition in the vertical direction; in this decomposition, the first mode is essentially a (linearized) Euler flow, then a few modes correspond to a stationary problem partly elliptic and partly hyperbolic; finally all the other modes correspond to a stationary problem fully hyperbolic.
RTT07.pdf (242.4 Ko) Télécharger le fichier
inria-00179961 , version 1 (17-10-2007)
Antoine Rousseau, Roger M. Temam, Joe Tribbia. The 3D Primitive Equations in the absence of viscosity: boundary conditions and well-posedness in the linearized case. Journal de Mathématiques Pures et Appliquées, 2008, 89 (3), pp.297-319. ⟨10.1016/j.matpur.2007.12.001⟩. ⟨inria-00179961⟩
289 Consultations
243 Téléchargements
