A Note on Sliced Inverse Regression with Regularizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biometrics Année : 2008
In "Li, L. and Yin, X. (2007). Sliced Inverse Regression with Regularizations., Biometrics, 64(1), 124-131" a ridge SIR estimator is introduced as the solution of a minimization problem and computed thanks to an alternating least-squares algorithm. This methodology reveals good performance in practice. In this note, we focus on the theoretical properties of the estimator. Is it shown that the minimization problem is degenerated in the sense that only two situations can occur: Either the ridge SIR estimator does not exist or it is zero.
liyin3.pdf (108.41 Ko) Télécharger le fichier
inria-00180496 , version 1 (19-10-2007)
inria-00180496 , version 2 (23-04-2013)
Caroline Bernard-Michel, Laurent Gardes, Stéphane Girard. A Note on Sliced Inverse Regression with Regularizations. Biometrics, 2008, 64 (3), pp.982-986. ⟨10.1111/j.1541-0420.2008.01080.x⟩. ⟨inria-00180496v2⟩
203 Consultations
302 Téléchargements
