Dynamic environment modeling with gridmap: a multiple-object tracking application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The Bayesian occupancy filter (BOF) has achieved promising results in the object tracking applications. This paper presents a new development of BOF which inherits original BOFs advantages in handling occlusion and representing objects shape. Meanwhile, the new formulation has significantly reduced original BOFs complexities and can be run in realtime. In Bayesian occupancy filter, the environment is finely divided into 2-dimensional grids. Different from conventional occupancy gridmaps, in BOF, each grid has both static (occupancy) and dynamic (velocity) characteristics. In the new proposed BOF, the velocity of each cell is modeled as a distribution. The distribution for each cell occupancy can therefore be inferred using a filtering mechanism. Like the original BOF, no representation of objects exists in the BOF gridmap. However, there are often applications which require the definition and tracking at the object level. In the post-processing, a segmentation algorithm is implemented to extract the objects from BOF estimation. Thereafter, standard target tracking methods are employed to further analyze each objects motion. Experiments using data from an indoor human tracking application demonstrate that our approach yields satisfactory results even when serious occlusions exist.
Autre [cs.OH]
CTML06.pdf (1.21 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00182007 , version 1 (24-10-2007)
  • HAL Id : inria-00182007 , version 1
Cheng Chen, Christopher Tay, Kamel Mekhnacha, Christian Laugier. Dynamic environment modeling with gridmap: a multiple-object tracking application. Proc. of the Int. Conf. on Control, Automation, Robotics and Vision, Dec 2006, Singapour, Singapore. ⟨inria-00182007⟩
153 Consultations
856 Téléchargements
