Fast Object Extraction from Bayesian Occupancy Grids Using Self Organizing Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Despite their popularity, occupancy grids cannot be directly applied to problems where the identity of the objects populating an environment needs to be taken into account (eg object tracking, scene interpretation, etc), in this cases it is necessary to postprocess the grid in order to extract object information. This paper approaches the problem by proposing a novel algorithm inspired on image segmentation techniques. The proposed approach works without prior knowledge about the number of objects to be detected and, at the same time, is very fast. This is possible thanks to the use of a novel Self Organizing Network (SON) coupled with a dynamic threshold. Our experimental results on both real and simulated data show that our approach is robust and able to operate at normal camera framerate.
Autre [cs.OH]
P1468.pdf (1006.25 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
Format : Autre
inria-00182011 , version 1 (24-10-2007)
  • HAL Id : inria-00182011 , version 1
Dizan Alejandro Vasquez Govea, Fabrizio Romanelli, Thierry Fraichard, Christian Laugier. Fast Object Extraction from Bayesian Occupancy Grids Using Self Organizing Networks. Proc. of the Int. Conf. on Control, Automation, Robotics and Vision (ICARCV), Dec 2006, Singapore (SG), France. ⟨inria-00182011⟩
137 Consultations
465 Téléchargements
