s'authentifier
version française rss feed
inria-00184762, version 1
Division Algorithms for Bernstein Polynomials
Laurent Busé () a1, Ron Goldman b2
Computer Aided Geometric Design 25, 9 (2008) 850--865
Résumé : Three division algorithms are presented for univariate Bernstein polynomials: an algorithm for finding the quotient and remainder of two univariate polynomials, an algorithm for calculating the GCD of an arbitrary collection of univariate polynomials, and an algorithm for computing a mu-basis for the syzygy module of an arbitrary collection of univariate polynomials. Division algorithms for multivariate Bernstein polynomials and analogues in the multivariate Bernstein setting of Grobner bases are also discussed. All these algorithms are based on a simple ring isomorphism that converts each of these problems from the Bernstein basis to an equivalent problem in the monomial basis. This isomorphism allows all the computations to be performed using only the original Bernstein coefficients; no conversion to monomial coefficients is required.
  • Domaine : Informatique/Calcul formel
  • inria-00184762, version 1
  • oai:hal.inria.fr:inria-00184762
  • Contributeur :
  • Soumis le : Jeudi 1 Novembre 2007, 14:44:00
  • Dernière modification le : Mardi 17 Mars 2009, 10:38:43
tous les articles de la base du CCSd...
