inria-00186401, version 1
Trajectory-Based Video Indexing and Retrieval Enabling Relevance Feedback
Thi Lan Le
1Alain Boucher 2Monique Thonnat 1
First International Conference on Communications and Electronics (ICCE'06) (2006)
Résumé : This paper is proposing an approach for retrieving videos based on object trajectories. First, a trajectory is translated into a sequence of symbols based on a symbolic representation, beyond the initial numeric representation, which does not suffer from scaling, translation or rotation. Then, in order to compare trajectories based on their symbolic representations, two similarity measures are proposed, inspired by works in bioinformatic. Moreover, based on these similarity measures, two relevance feedback strategies are given. Experimental results for two databases show that the proposed similarity measures gave results as good as other existing measures. Real advantages of these measures are the possibility for the partial matching and for relevance feedback.
- 1 : ORION (INRIA Sophia Antipolis)
- INRIA
- 2 : IFI
- IFI
- Domaine : Informatique/Traitement des images
- inria-00186401, version 1
- http://hal.inria.fr/inria-00186401
- oai:hal.inria.fr:inria-00186401
- Contributeur : Thi Lan Le
- Soumis le : Vendredi 9 Novembre 2007, 06:26:17
- Dernière modification le : Vendredi 9 Novembre 2007, 09:11:57
Documents associés
Exporter
