Improved Stage 2 to P$\pm$1 Factoring Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Some implementations of stage 2 of the P-1 method of factorization use convolutions. We describe a space-efficient implementation, allowing convolution lengths around 2^23 and stage 2 limit around 10^16 while attempting to factor 230-digit numbers on modern PC's. We use the discrete cosine transform to multiply reciprocal polynomials. We present adjustments for the P+1 algorithm. We list some new findings.
pm1fft-final.pdf (251.7 Ko) Télécharger le fichier
inria-00188192 , version 1 (15-11-2007)
inria-00188192 , version 2 (15-01-2008)
inria-00188192 , version 3 (06-11-2008)
Peter Lawrence Montgomery, Alexander Kruppa. Improved Stage 2 to P$\pm$1 Factoring Algorithms. 8th International Symposium on Algorithmic Number Theory - ANTS-VIII, May 2008, Waterloo, Canada. pp.180-195, ⟨10.1007/978-3-540-79456-1_12⟩. ⟨inria-00188192v3⟩
105 Consultations
825 Téléchargements
