A distribution framework for the fast identification of linear systems with delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper deals with on line identification of delay systems. The work is based on the approach initiated in (Fliess M., 2003) and extended to delays identification
Automatique
Reg_tds_053_belkoura2.pdf (141.66 Ko) Télécharger le fichier
inria-00189522 , version 1 (21-11-2007)
  • HAL Id : inria-00189522 , version 1
Lotfi Belkoura, Jean-Pierre Richard. A distribution framework for the fast identification of linear systems with delays. 6th IFAC Workshop on Time Delay Systems, 2006, l'Aquila, Italy. ⟨inria-00189522⟩
317 Consultations
259 Téléchargements
