Back and forth nudging algorithm for data assimilation problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2005
In this Note, we introduce a new algorithm for data assimilation problems, called the back and forth nudging (BFN) algorithm. The standard forward nudging algorithm is first studied for a linear ODE model. The backward nudging algorithm is then introduced in order to reconstruct the initial state of the system. These two algorithms are combined in the new BFN algorithm. The mathematical proof of its convergence is given for a linear ODE system.
auroux_CRAS2.pdf (96.67 Ko) Télécharger le fichier
inria-00189644 , version 1 (21-11-2007)
Didier Auroux, Jacques Blum. Back and forth nudging algorithm for data assimilation problems. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2005, 340, pp.873-878. ⟨10.1016/j.crma.2005.05.006⟩. ⟨inria-00189644⟩
276 Consultations
545 Téléchargements
