Multimedia document summarization based on a semantic adaptation framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The multiplication of presentation contexts (such as mobile phones, PDAs) for multimedia documents requires the adaptation of document specifications. In an earlier work, a semantic framework for multimedia document adaptation was proposed. This framework deals with the semantics of the document composition by transforming the relations between multimedia objects. However, it was lacking the capability of suppressing multimedia objects. In this paper, we extend the proposed adaptation with this capability. Thanks to this extension, we present a method for summarizing multimedia documents. Moreover, when multimedia objects are removed, the resulted document satisfies some properties such as presentation contiguity. To validate our framework, we adapt standard multimedia documents such as SMIL documents.
SADPI07.pdf (504.58 Ko) Télécharger le fichier
inria-00192895 , version 1 (29-11-2007)
Sébastien Laborie, Jérôme Euzenat, Nabil Layaïda. Multimedia document summarization based on a semantic adaptation framework. International workshop on Semantically aware document processing and indexing, ACM, May 2007, Montpellier, France. ⟨10.1145/1283880.1283896⟩. ⟨inria-00192895⟩
717 Consultations
219 Téléchargements
