s'authentifier
version française rss feed
inria-00192927, version 1
Maintaining Visibility Information of Planar Point Sets with a Moving Viewpoint
Olivier Devillers () 1, Vida Dujmovic 2, Hazel Everett () 3, Samuel Hornus 4, Sue Whitesides 5, Steve Wismath 6
International Journal of Computational Geometry & Applications 17, 4 (2007) 297-304
Résumé : Given a set of n points in the plane, we consider the problem of computing the circular ordering of the points about a viewpoint q and efficiently maintaining this ordering information as q moves. In linear space, and after O(n log n) preprocessing time, our solution maintains the view at a cost of O(log n) amortized time (resp. O(log^2 n) worst case time) for each change. Our algorithm can also be used to maintain the set of points sorted according to their distance to q.
  • Domaine : Informatique/Géométrie algorithmique
  • Mots-clés : visibility – dynamic data structures
  • inria-00192927, version 1
  • oai:hal.inria.fr:inria-00192927
  • Contributeur :
  • Soumis le : Jeudi 29 Novembre 2007, 17:20:27
  • Dernière modification le : Mardi 4 Décembre 2007, 20:32:38
tous les articles de la base du CCSd...
