Tournament MAC with Constant Size Congestion Window for WLAN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the context of radio distributed networks, we present a generalized approach for the Medium Access Control (MAC) with fixed congestion window. Our protocol is quite simple to analyze and can be used in a lot of different situations. We give mathematical evidence showing that our performance is tight, in the sense that no protocol with fixed congestion window can do better. We also place ourselves in the WiFi/WiMAX framework, and show experimental results enlightening collision reduction of 14% to 21% compared to the best known other methods. We show channel capacity improvement, and fairness considerations.
RR-6396.pdf (281.2 Ko) Télécharger le fichier
inria-00195965 , version 1 (11-12-2007)
inria-00195965 , version 2 (19-12-2007)
  • HAL Id : inria-00195965 , version 2
  • ARXIV : 0712.1803
Jérôme Galtier. Tournament MAC with Constant Size Congestion Window for WLAN. [Research Report] RR-6396, INRIA. 2007, pp.23. ⟨inria-00195965v2⟩
103 Consultations
85 Téléchargements
