Visually-Guided Robot Navigation: From Artificial To Natural Landmarks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Landmark-based navigation in unknown unstructured environments is far from solved. The bottleneck nowadays seems to be the fast detection of reliable visual references in the image stream as the robot moves. In our research, we have decoupled the navigation issues from this visual bottleneck, by first using artificial landmarks that could be easily detected and identified. Once we had a navigation system working, we developed a strategy to detect and track salient regions along image streams by just performing on-line pixel sampling. This strategy continuously updates the mean and covariances of the salient regions, as well as creates, deletes and merges regions according to the sample flow. Regions detected as salient can be considered as potential landmarks to be used in the navigation task.
fsr_60.pdf (574.27 Ko) Télécharger le fichier
inria-00196177 , version 1 (12-12-2007)
  • HAL Id : inria-00196177 , version 1
Enric Celaya, Jose-Luis Albarral, Pablo Jiménez, Carme Torras. Visually-Guided Robot Navigation: From Artificial To Natural Landmarks. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00196177⟩
Collections
FSR2007
37 Consultations
188 Téléchargements
