Modeling of Immediate vs. Delayed Data Communications: from AADL to UML MARTE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The forthcoming OMG UML Profile for Modeling and Analysis of Real-Time Embedded systems (MARTE) aims, amongst other things, at providing a referential Time Model subprofile where semantic issues can be explicitly and formally described. As a full-size exercise we deal here with the modeling of immediate and delayed data communications in AADL. It actually reflects an important issue in RT/E model semantics: a propagation of immediate communications may result in a combinatorial loop, with ill-defined behavior; introduction of delays may introduce races, which have to be controlled. We describe here the abilities of MARTE in this respect.
Mots clés
FDL07a.pdf (151.47 Ko) Télécharger le fichier
inria-00204484 , version 1 (27-03-2009)
  • HAL Id : inria-00204484 , version 1
Charles André, Frédéric Mallet, Robert de Simone. Modeling of Immediate vs. Delayed Data Communications: from AADL to UML MARTE. ECSI Forum on specification & Design Languages (FDL), ECSI, Sep 2007, Barcelona, Spain. pp.249-254. ⟨inria-00204484⟩
605 Consultations
179 Téléchargements
