Concurrency Awareness in a P2P Wiki System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Sawsan Alshattnawi
  • Fonction : Auteur
  • PersonId : 830772
Gérôme Canals
  • Fonction : Auteur
  • PersonId : 830484
Pascal Molli
Currently, Wikis are the most popular form of collaborative editors. Recently, some researches have been done to shift from traditional centralized architecture to fully decentralized wikis relying on peer-to-peer networks. This architecture improves scalability and fault-tolerance, but subtly changes the behavior of wiki in case of concurrent changes. While traditional wikis ensure that all wiki pages have been reviewed by, at least, a human, some pages in P2P wiki systems can be the result of an automatic merge done by the system. This forces P2P wiki systems to integrate a concurrency awareness system to notify users about the status of wiki pages. The particular context of a P2P wiki system makes traditional awareness mechanisms inadequate. In this paper, we present a new concurrency awareness mechanism designed for P2P wiki systems.
RR-6429.pdf (557.99 Ko) Télécharger le fichier
inria-00216196 , version 1 (24-01-2008)
inria-00216196 , version 2 (25-01-2008)
  • HAL Id : inria-00216196 , version 2
Sawsan Alshattnawi, Gérôme Canals, Pascal Molli. Concurrency Awareness in a P2P Wiki System. [Research Report] RR-6425, INRIA. 2008, pp.18. ⟨inria-00216196v2⟩
271 Consultations
508 Téléchargements
