Nonlinear V6 schemes for compressible flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We describe several numerical schemes for conservation laws well adapted to nonlinear aerodynamics. The schemes are vertex centered, dissipative. They apply with second-order accuracy to unstructured tetrahedrizations and extend to higher order (up to sixth) on a certain type of Cartesian triangulations/tetrahedrizations.
RR-6433.pdf (393.6 Ko) Télécharger le fichier
inria-00224120 , version 1 (30-01-2008)
inria-00224120 , version 2 (31-01-2008)
  • HAL Id : inria-00224120 , version 2
Bruno Koobus, Stephen F. Wornom, Simone Camarri, Maria-Vittoria Salvetti, Alain Dervieux. Nonlinear V6 schemes for compressible flow. [Research Report] INRIA. 2008, pp.37. ⟨inria-00224120v2⟩
541 Consultations
356 Téléchargements
