QAS: Real-time Quadratic Approximation of Subdivision Surfaces. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We introduce QAS, an efficient quadratic approximation of subdivision surfaces which offers a very close appearance compared to the true subdivision surface but avoids recursion, providing at least one order of magnitude faster rendering. QAS uses enriched polygons, equipped with edge vertices, and replaces them on-the-fly with low degree polynomials for interpolating positions and normals. By systematically projecting the vertices of the input coarse mesh at their limit position on the subdivision surface, the visual quality of the approximation is good enough for imposing only a single subdivision step, followed by our patch fitting, which allows real-time performances for million polygons output. Additionally, the parametric nature of the approximation offers an efficient adaptive sampling for rendering and displacement mapping. Last, the hexagonal support associated to each coarse triangle is adapted to geometry processors.
QAS.pdf (562.21 Ko) Télécharger le fichier
inria-00260834 , version 1 (05-03-2008)
  • HAL Id : inria-00260834 , version 1
Tamy Boubekeur, Christophe Schlick. QAS: Real-time Quadratic Approximation of Subdivision Surfaces.. Pacific Graphics, Oct 2007, Hawaii, United States. ⟨inria-00260834⟩
133 Consultations
631 Téléchargements
