Fiacre: an Intermediate Language for Model Verification in the Topcased Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Fiacre was designed in the framework of the TOPCASED project dealing with model-driven engineering and gathering numerous partners, from both industry and academics. Therefore, Fiacre is designed both as the target language of model transformation engines from various models such as SDL, UML, AADL, and as the source language of compilers into the targeted verification toolboxes, namely CADP and Tina in the first step. In this paper, we present the Fiacre language. Then transformations from AADL to Fiacre are illustrated on a small example.
Berthomieu-Bodeveix-Farail-et-al-08.pdf (143.04 Ko) Télécharger le fichier
inria-00262442 , version 1 (11-03-2008)
  • HAL Id : inria-00262442 , version 1
Bernard Berthomieu, Jean-Paul Bodeveix, Patrick Farail, M Filali, Hubert Garavel, et al.. Fiacre: an Intermediate Language for Model Verification in the Topcased Environment. 4th European Congress ERTS Embedded Real Time Software (ERTS 2008), SEE : Société de l'électricité, de l'électronique et des technologies de l'information et de la communication; 3AF : Association Aéronautique et Astronautique de France, Jan 2008, Toulouse, France. pp.1-8. ⟨inria-00262442⟩
1142 Consultations
891 Téléchargements
