Convergence of a simple adaptive finite element method for optimal control
We prove convergence and optimal complexity of an adaptive finite element algorithm for a model problem of optimal control. Following previous work, our algorithm is based on an adaptive marking strategy which compares a simple edge estimator with an oscillation term in each step of the algorithm in order to adapt the marking of cells.
