The arithmetic of characteristic 2 Kummer surfaces and of elliptic Kummer lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Finite Fields and Their Applications Année : 2009
The purpose of this paper is a description of a model of Kummer surfaces in characteristic 2, together with the associated formulas for the pseudo-group law. Since the classical model has bad reduction, a renormalization of the parameters is required, that can be justified using the theory of algebraic theta functions. The formulas that are obtained are very efficient and may be useful in cryptographic applications. We also show that applying the same strategy to elliptic curves gives Montgomery-like formulas in odd characteristic that are faster than the classical ones, and we recover already known formulas by Stam in characteristic 2.
c2.pdf (222.53 Ko) Télécharger le fichier
inria-00266565 , version 1 (25-03-2008)
inria-00266565 , version 2 (20-05-2009)
Pierrick Gaudry, David Lubicz. The arithmetic of characteristic 2 Kummer surfaces and of elliptic Kummer lines. Finite Fields and Their Applications, 2009, 15 (2), pp.246-260. ⟨10.1016/j.ffa.2008.12.006⟩. ⟨inria-00266565v2⟩
391 Consultations
325 Téléchargements
