State Space Sampling of Feasible Motions for High Performance Mobile Robot Navigation in Highly Constrained Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Thomas M. Howard
  • Fonction : Auteur
  • PersonId : 848020
Colin J. Green
  • Fonction : Auteur
  • PersonId : 848021
Alonso Kelly
  • Fonction : Auteur
  • PersonId : 848022
Sampling in the space of controls or actions is a well-established method for ensuring feasible local motion plans. However, as mobile robots advance in performance and competence in complex outdoor environments, this classical motion planning technique ceases to be effective. When environmental constraints severely limit the space of acceptable motions or when global motion planning expresses strong preferences, a state space sampling strategy is more effective. While this has been clear for some time, the practical question is how to achieve it while also satisfying the severe constraints of vehicle dynamic feasibility. This paper presents an effective algorithm for state space sampling based on a model-based trajectory generation approach. This method enables high-speed navigation in highly constrained and/or partially known environments such as trails, roadways, and dense off-road obstacle fields.
fsr_72.pdf (482.91 Ko) Télécharger le fichier
inria-00268023 , version 1 (31-03-2008)
  • HAL Id : inria-00268023 , version 1
Thomas M. Howard, Colin J. Green, Alonso Kelly. State Space Sampling of Feasible Motions for High Performance Mobile Robot Navigation in Highly Constrained Environments. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00268023⟩
Collections
FSR2007
205 Consultations
538 Téléchargements
