Monte Carlo Localization in Outdoor Terrains using Multi-Level Surface Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper we consider the problem of mobile robot localization with range sensors in outdoor environments. Our approach applies a particle filter to estimate the full six-dimensional state of the robot. To represent the environment we utilize multi-level surface maps which allow the robot to represent vertical structures and multiple levels in the environment. We describe probabilistic motion and sensor models to calculate the proposal distribution and to evaluate the likelihood of observations. Experimental results obtained with a mobile robot in an outdoor environment indicate that our approach can be used to robustly and accurately localize an outdoor vehicle. The experiments also demonstrate that multi-level surface maps lead to a significantly better localization performance than standard elevation maps.
fsr_38.pdf (647.3 Ko) Télécharger le fichier
inria-00275583 , version 1 (24-04-2008)
  • HAL Id : inria-00275583 , version 1
Rainer Kummerle, Rudolph Triebel, Patrick Pfaff, Wolfram Burgard. Monte Carlo Localization in Outdoor Terrains using Multi-Level Surface Maps. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00275583⟩
Collections
FSR2007
93 Consultations
487 Téléchargements
