A Semantic Normalization Proof for Inductive Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Semantics methods have been used to prove cut elimination theorems for a long time. It is only recently that they have been extended to prove strong normalization results. For instance using the notion of super-consistency that is a semantic criterion for theories expressed in deduction modulo implying strong normalization. However, the strong normalization of System T has always been reluctant to such semantic methods. In this paper we give a semantic normalization proof of system T using the super consistency of some theory. We then extend the result to every strictly positive inductive type and discuss the extension to predicate logic.
paper.pdf (250.1 Ko) Télécharger le fichier
inria-00280410 , version 1 (17-05-2008)
inria-00280410 , version 2 (19-05-2008)
  • HAL Id : inria-00280410 , version 2
Lisa Allali, Paul Brauner. A Semantic Normalization Proof for Inductive Types. [Research Report] 2008, pp.21. ⟨inria-00280410v2⟩
185 Consultations
80 Téléchargements
