The vertebrate retina: a functional review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this report, we summarize the major properties of retinal filtering and organization, as understood by numerous experiments and models over the last decades. For this review, we take a functional approach, trying to answer this apparently simple question: What are the main characteristics of the retinal output in terms of signal processing, which should be retained in a functional model?
Neurobiologie
RR_bio.pdf (14.33 Mo) Télécharger le fichier
inria-00280693 , version 1 (19-05-2008)
  • HAL Id : inria-00280693 , version 1
Adrien Wohrer. The vertebrate retina: a functional review. [Research Report] RR-6532, INRIA. 2008, pp.186. ⟨inria-00280693⟩
199 Consultations
346 Téléchargements
