Wireless Broadcast with Network Coding in Mobile Ad-Hoc Networks: DRAGONCAST - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Network coding is a recently proposed method for transmitting data, which has been shown to have potential to improve wireless network performance. We study network coding for one specific case of multicast, broadcasting, from one source to all nodes of the network. We use network coding as a loss tolerant, energy-efficient, method for broadcast. Our emphasis is on mobile networks. Our contribution is the proposal of DRAGONCAST, a protocol to perform network coding in such a dynamically evolving environment. It is based on three building blocks: a method to permit real-time decoding of network coding, a method to adjust the network coding transmission rates, and a method for ensuring the termination of the broadcast. The performance and behavior of the method are explored experimentally by simulations; they illustrate the excellent performance of the protocol.
RR-6569.pdf (387.3 Ko) Télécharger le fichier
inria-00292867 , version 1 (02-07-2008)
  • HAL Id : inria-00292867 , version 1
  • ARXIV : 0807.0425
Song Yean Cho, Cédric Adjih. Wireless Broadcast with Network Coding in Mobile Ad-Hoc Networks: DRAGONCAST. [Research Report] RR-6569, INRIA. 2008. ⟨inria-00292867⟩
241 Consultations
150 Téléchargements
