MILEPOST GCC: machine learning based research compiler - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Tuning hardwired compiler optimizations for rapidly evolving hardware makes porting an optimizing compiler for each new platform extremely challenging. Our radical approach is to develop a modular, extensible, self-optimizing compiler that automatically learns the best optimization heuristics based on the behavior of the platform. In this paper we describe MILEPOST GCC, a machine-learning-based compiler that automatically adjusts its optimization heuristics to improve the execution time, code size, or compilation time of specific programs on different architectures. Our preliminary experimental results show that it is possible to considerably reduce execution time of the MiBench benchmark suite on a range of platforms entirely automatically.
fmtp2008.pdf (192.7 Ko) Télécharger le fichier
inria-00294704 , version 1 (10-07-2008)
  • HAL Id : inria-00294704 , version 1
Grigori Fursin, Cupertino Miranda, Olivier Temam, Mircea Namolaru, Elad Yom-Tov, et al.. MILEPOST GCC: machine learning based research compiler. GCC Summit, Jun 2008, Ottawa, Canada. ⟨inria-00294704⟩
1645 Consultations
1141 Téléchargements
