The Combined Power of Conditions and Information on Failures to Solve Asynchronous Set Agreement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
To cope with the impossibility of solving agreement problems in asynchronous systems made up of n processes and prone to t process crashes, system designers tailor their algorithms to run fast in “normal” circumstances. Two orthogonal notions of “normality” have been studied in the past through failure detectors that give processes information about process crashes, and through conditions that restrict the inputs to an agreement problem. This paper investigates how the two approaches can benefit from each other to solve the k-set agreement problem, where processes must agree on at most k of their input values (when k = 1 we have the famous consensus problem). It proposes novel failure detectors for solving k-set agreement, and a protocol that combines them with conditions, establishing a new bridge among asynchronous, synchronous and partially synchronous systems with respect to agreement problems. The paper proves also a lower bound when solving the k-set agreement problem with a condition.
PI-1897.pdf (291.15 Ko) Télécharger le fichier
inria-00294706 , version 1 (10-07-2008)
  • HAL Id : inria-00294706 , version 1
Achour Mostefaoui, Sergio Rajsbaum, Michel Raynal, Corentin Travers. The Combined Power of Conditions and Information on Failures to Solve Asynchronous Set Agreement. [Research Report] PI 1897, 2008, pp.30. ⟨inria-00294706⟩
284 Consultations
276 Téléchargements
