Ghost force reduction and spectral analysis of the 1D bridging method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this paper we study the Bridging Method recently developed by T. Belytschko and S. Xiao to couple continuum mechanics with molecular dynamics. This method uses an overlap zone where both models exist and where degrees of freedom are coupled. We analyze the method in the 1D case. Firstly, we show that the spatial weighting of the potential energy leads to some appreciable numerical artifacts. Then, after presenting a modification of the time integration scheme that removes such spurious effects, we introduce the method employed to numerically measure the wave reflection rates. The limitation of these reflections constitute a major issue in all existing coupling methods for dynamics simulations. After discussing some first results achieved from numerical measurements, we present a spectral analysis that attempts to explain the behavior of the coupling zone by treating it as an independent material. The predictions of this spectral analysis are finally compared to some parametric studies issued from 1D coupling simulations.
RR-6582.pdf (523.16 Ko) Télécharger le fichier
inria-00300603 , version 1 (18-07-2008)
  • HAL Id : inria-00300603 , version 1
Guillaume Anciaux, Olivier Coulaud, Jean Roman, Gilles Zerah. Ghost force reduction and spectral analysis of the 1D bridging method. [Research Report] RR-6582, INRIA. 2008. ⟨inria-00300603⟩
310 Consultations
251 Téléchargements
