A Virtual Document Interpreter for Reuse of Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
The importance of reuse of information is well recognised for electronic publishing. However, it is rarely achieved satisfactorily because of the complexity of the task: integrating different formats, handling updates of information, addressing document author's need for intuitiveness and simplicity, etc. An approach which addresses these problems is to dynamically generate and update documents through a descriptive definition of virtual documents. In this paper we present a document interpreter that allows gathering information from multiple sources, and combining it dynamically to produce a virtual document. Two strengths of our approach are: the generic information objects that we use, which enables access to distributed, heterogeneous data sources; and the interpreter's evaluation strategy, which permits a minimum of re-evaluation of the information objects from the data sources.
ep98-F.pdf (96.76 Ko) Télécharger le fichier
inria-00304339 , version 1 (22-07-2008)
  • HAL Id : inria-00304339 , version 1
François Paradis, Anne-Marie Vercoustre, Brendan Hills. A Virtual Document Interpreter for Reuse of Information. the 7th International Conference on Electronic Publishing (EP'98), Apr 1998, Saint-Malo, France. pp. 487 - 498. ⟨inria-00304339⟩
Collections
INRIA INRIA2
68 Consultations
331 Téléchargements
