TuLiPA: Towards a Multi-Formalism Parsing Environment for Grammar Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Timm Lichte
  • Fonction : Auteur
Johannes Dellert
  • Fonction : Auteur
  • PersonId : 848626
Kilian Evang
  • Fonction : Auteur
  • PersonId : 852385
In this paper, we present an open-source parsing environment (Tuebingen Linguistic Parsing Architecture, TuLiPA) which uses Range Concatenation Grammar (RCG) as a pivot formalism, thus opening the way to the parsing of several mildly context-sensitive formalisms. This environment currently supports tree-based grammars (namely Tree-Adjoining Grammars, TAG) and Multi-Component Tree-Adjoining Grammars with Tree Tuples (TT-MCTAG)) and allows computation not only of syntactic structures, but also of the corresponding semantic representations. It is used for the development of a tree-based grammar for German.
tulipa-geaf08.pdf (321.44 Ko) Télécharger le fichier
inria-00304605 , version 1 (23-07-2008)
  • HAL Id : inria-00304605 , version 1
  • ARXIV : 0807.3622
Laura Kallmeyer, Timm Lichte, Wolfgang Maier, Yannick Parmentier, Johannes Dellert, et al.. TuLiPA: Towards a Multi-Formalism Parsing Environment for Grammar Engineering. 2nd Workshop on Grammar Engineering Across Frameworks, GEAF 2008, Stephen Clark, Oxford and Tracy Holloway King, PARC, Aug 2008, Manchester, United Kingdom. pp._. ⟨inria-00304605⟩
73 Consultations
323 Téléchargements
