s'authentifier
version française rss feed
inria-00305302, version 3
Efficient Static Analysis of XML Paths and Types
Pierre Genevès () a1, Nabil Layaïda () a1, Alan Schmitt () a2
N° RR-6590 (2008)
Résumé : We present an algorithm to solve XPath decision problems under regular tree type constraints and show its use to statically type-check XPath queries. To this end, we prove the decidability of a logic with converse for finite ordered trees whose time complexity is a simple exponential of the size of a formula. The logic corresponds to the alternation free modal mu-calculus without greatest fixpoint, restricted to finite trees, and where formulas are cycle-free. Our proof method is based on two auxiliary results. First, XML regular tree types and XPath expressions have a linear translation to cycle-free formulas. Second, the least and greatest fixpoints are equivalent for finite trees, hence the logic is closed under negation. Building on these results, we describe a practical, effective system for solving the satisfiability of a formula. The system has been experimented with some decision problems such as XPath emptiness, containment, overlap, and coverage, with or without type constraints. The benefit of the approach is that our system can be effectively used in static analyzers for programming languages manipulating both XPath expressions and XML type annotations (as input and output types).
  • Domaine : Informatique/Base de données
    Informatique/Langage de programmation
    Informatique/Web
  • Mots-clés : Mu-calculus – satisfiability – trees – XPath – queries – XML – types – regular tree grammars – static analysis
  • Référence interne : RR-6590
  • Versions disponibles :  v1 (23-07-2008) v2 (23-07-2008) v3 (24-07-2008)
  • inria-00305302, version 3
  • oai:hal.inria.fr:inria-00305302
  • Contributeur :
  • Soumis le : Jeudi 24 Juillet 2008, 11:08:04
  • Dernière modification le : Mercredi 6 Août 2008, 11:14:55
tous les articles de la base du CCSd...
