From images to shape models for object detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Vittorio Ferrari
  • Fonction : Auteur
  • PersonId : 852592
Frédéric Jurie
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
We present an object class detection approach which fully integrates the complementary strengths offered by shape matchers. Like an object detector, it can learn class models directly from images, and localize novel instances in the presence of intra-class variations, clutter, and scale changes. Like a shape matcher, it finds the boundaries of objects, rather than just their bounding-boxes. This is made possible by a novel technique for learning a shape model of an object class given {\em images} of example instances. Furthermore, we also integrate Hough-style voting with a non-rigid point matching algorithm to localize the model in cluttered images. As demonstrated by an extensive evaluation, our method can localize object boundaries accurately, while needing no segmented examples for training (only bounding-boxes)
RR-6600.pdf (2.3 Mo) Télécharger le fichier
Format : Figure, Image
inria-00308388 , version 1 (30-07-2008)
  • HAL Id : inria-00308388 , version 1
Vittorio Ferrari, Frédéric Jurie, Cordelia Schmid. From images to shape models for object detection. [Research Report] RR-6600, INRIA. 2008. ⟨inria-00308388⟩
256 Consultations
1063 Téléchargements
